[gdal-dev] VRT images and overview types
Armin Burger armin.burger at gmx.net
Mon Jun 22 15:40:04 EDT 2009
Hi everybody
I noticed some strange behaviour of virtual images with the Erdas RRD
overview type. I am using VRT images referencing Geotiff files and
applying image stretching parameters (offset and scale) to improve the
display in Mapserver applications. The VRT images are created with
Python and GDAL bindings. This works fine if the overview is created
e.g. with the -ro flag, the stretching parameters are then applied at
all overview levels.
If I create the overviews using the Erdas format (--config USE_RRD YES)
then the vrt image is applying the stretching parameters only in case
the full Tiff image is read. At a scale level where just the overview
file is read the stretching parameters are not applied. This causes a
confusing display effect by enabling the stretching at a certain scale.
I'd prefer to continue with the RRD overviews since the images are also
read via Desktop programs like Erdas or ArcMap that make use of the RRD
.aux files. Is there a way to have RRD overviews and stretching
parameters applied on them as well? Or would this be possible in future
GDAL versions?
Thanks for any clarification
Armin
