[Gdal-dev] GDAL problems with IDLE
JPKay kay1829 at vandals.uidaho.edu
Mon Jun 22 16:47:08 EDT 2009
Hello,
I am trying to install GDAL on my mac running OS x 10.5.7 using python
2.5.4. I have followed the directions to build from the cheese shop, however
when I go over to IDLE and try  the command "from osgeo import ogr" I get
the following error: ImportError: No module named osgeo. I assume this means
that the libraries can't find each other. Any thoughts on this topic would
be appreciated.
Thanks in advance,
Jon
View this message in context: http://n2.nabble.com/GDAL-problems-with-IDLE-tp3138630p3138630.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
