[gdal-dev] Build OGR with Oracle support
Mateusz Loskot
mateusz at loskot.net
Tue Jun 23 18:38:48 EDT 2009
Andreas Neumann wrote:
> ok - the problem could now be solved by setting the library path in
> /etc/ld.so.conf.d/oracle.conf and running ldconfig as root. Then all the
> libraries could be found. Somehow the LD_LIBRARY_PATH variable was
> constantly ignored, although it was set and could be queried with echo
> $LD_LIBRARY_PATH. It was interesting that LD_LIBRARY_PATH worked as root,
> but not as a regular user, but the method with ldconfig worked for all
> users.
> Thank you for all of your help!
Andreas,
Check if directory with libnnz has +x privileges for your non-root
users. IOW, check if you can step into this directory as non-root user.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
