[gdal-dev] Re:[FWTools] GDALRasterizeGeometries() and Python
Matthieu Rigal
rigal at rapideye.de
Mon Jun 29 08:59:35 EDT 2009
Hi Frank and GDAL-dev team,
By reading the following message and unsuccessfully searching for
documentation and possibilities to rasterize geometries, I would be pleased
to know if the Python bindings for GDALRasterizeGeometries() are still
somehow planned.
If no bindings are planned is there another work-around than invoking the
utilities from the shell to mask raster data from vector data, within gdal or
within numpy (after ReadAsArray) ?
Best regards,
Matthieu
Travis,
I have checked, and can confirm that the rasterize geometries function
is not currently exposed in Python at all. I've been adding bindings for
some other algorithms this week, and I'll look at adding one for this too,
though I think it may be a bit tricky.
Best regards,
On Wed, Sep 17, 2008 at 11:39 AM, Travis Kirstine
<traviskirstine at gmail.com> wrote:
> I'm was hoping to use GDALRasterizeGeometries() from the gdal_agl.h
> file with python to burn polygons from PostGIS into a geotiff. I
> don't believe that there are python binding available, am I correct?
> Travis K.
> Toronto, Canada
> FWTools mailing list
> FWTools at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/fwtools
> http://fwtools.maptools.org/
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Follow us on Twitter! www.twitter.com/rapideye_ag
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
DIN EN ISO 9001 certified
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
