[gdal-dev] GDAL autotest failures on Windows
Even Rouault even.rouault at mines-paris.org
Sun Mar 1 12:11:16 EST 2009
Tamas,
I've just fixed the failures for bsb_online_1 (the online dataset had
apparently changed since I downloaded it) and hfa_delete_colortable (a file
copy was made in text mode instead of binary mode).
I've added a missing file close in the PCRaster driver in an error path that
might account for the failures on misc_5 and misc_6. And I've also added more
info in case of failure so that we can identify more easily the driver that
causes the error.
The failures in hfa_write.py and osr_esri.py also occur on Linux and are known
and reported in http://trac.osgeo.org/gdal/ticket/2755
The failure on aigrid_online_1 seems to reveal a bug in the AIGRID driver on
Windows. VSIStatL seems to fail on a directory whose name is
like 'foo/../info/' (in AIGDataset::ReadRAT())
My feeling on the failure on ogr_gml_4 is that it might be related to a recent
change in the GML driver (http://trac.osgeo.org/gdal/ticket/1017) on how we
fetch the FID of features.
On Linux, an ogrinfo on autotest/ogr/data/bom.gml now show the 3 features with
an identical fid = 2147483647.
On Windows, ogrinfo.exe loops endlessly and returns always the content of the
first feature with a fid = -416888225.
Le Sunday 01 March 2009 16:24:02 Tamas Szekeres, vous avez écrit :
> Hi Folks,
> I've managed to include the GDAL auto-tests with my regular builds on
> Windows. The stable branch has no failures.
> The SVN trunk  produces 17-18 failures for each compilers/architectures:
> ------------ Failures ------------
> Script: ogr/ogr_gml_read.py
>   TEST: ogr_gml_4 ... fail
>     Wrong featureCode field value
> Script: gcore/hfa_write.py
>   TEST: SetProjection: byte.tif ... fail
>     Did not get expected projection reference.
>   TEST: SetProjection: int16.tif ... fail
>   TEST: SetProjection: uint16.tif ... fail
>   TEST: SetProjection: int32.tif ... fail
>   TEST: SetProjection: uint32.tif ... fail
>   TEST: SetProjection: float32.tif ... fail
>   TEST: SetProjection: float64.tif ... fail
>   TEST: SetProjection: cfloat32.tif ... fail
>   TEST: SetProjection: cfloat64.tif ... fail
>   TEST: SetProjection: utmsmall.tif ... fail
> Script: gcore/misc.py
>   TEST: misc_5 ... fail (blowup)
>   TEST: misc_6 ... fail (blowup)
> Script: gdrivers/aigrid.py
>   TEST: aigrid_online_1 ... fail
>     No RAT found
> Script: gdrivers/bsb.py
>   TEST: bsb_online_1 ... fail
>     Checksum for band 1 in "tmp/cache/14850_1.KAP" is 63005, but expected
> 54674. Script: gdrivers/hfa.py
>   TEST: hfa_delete_colortable ... fail (blowup)
> Script: osr/osr_esri.py
>   TEST: osr_esri_15 ... fail
>     Did not get rectified_grid_angle as expected.
>   TEST: osr_esri_16 ... fail
>     Did not get expected equidistant cylindrical.
> Test Script: utilities/test_ogrtindex.py
> Succeeded: 1287
> Failed:    18 (3 blew exceptions)
> Skipped:   238
> Expected fail:0
> For more details about the issues you can inspect the build logs here:
> http://vbkto.dyndns.org:1280/sdk/index.html
> Best regards,
> Tamas
