[gdal-dev] problem accessing rows of an image in parallel
Yann Chemin yann.chemin at gmail.com
Sun Mar 1 21:48:09 EST 2009
Hello list,
I am working on an OpenMP implementation of an image processing
algorithm and was wondering if there is a known problem in accessing
different rows at the same time on the same band handle.
sometimes I get this (or similar):
ERROR 1: TIFFFillStrip:b4.tif: Seek error at scanline 186, strip 345
ERROR 1: TIFFReadEncodedStrip() failed.
ERROR 1: IReadBlock failed at X offset 0, Y offset 345
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 345
ERROR 1: TIFFFillStrip:b4.tif: Seek error at scanline 1269, strip 157
ERROR 1: IReadBlock failed at X offset 0, Y offset 157
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 157
On the original standard serial code, all is fine.
Thanks for any suggestions,
Yann
Yann Chemin
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
