[gdal-dev] Re: Building 64 bit, Swig Error
Tamas Szekeres szekerest at gmail.com
Fri Mar 6 18:17:31 EST 2009
2009/3/6 Tomas R <monshi at home.se>
> Ah, thanks, will look it up more properly in the morning.
> A quick check now did not reveal what may be missing. Strange, it is a
> fresh installations of the VSE 2008 and SDK. It should work. Or?
> Well, probably the version you linked to is good enough for me and also a
> 64 bit version of Proj4 is found in the pack, nice. That would probably be
> my next question , how to compile a 64 bit version of Proj4 using VSE2008.
> Or even 32 bit version. But 32 version is easy to find (FWTools for example)
> so that would be necessary.
If you use my SDK just download and extract the proj4 package (eg.
proj-4.6.1) within the SDK root directory and use:
nmake proj PROJ_DIR=proj-4.6.1
The Makefile will set the compiler version and the WIN64 setting seemlessly.
It seems like the @SET FrameworkDir=Framework32  should point to the
absolute path of the framework directory (ie
C:\WINDOWS\Microsoft.NET\Framework) in your batch file.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090307/50d27bf4/attachment.html
