[gdal-dev] Re: Building 64 bit, Swig Error
Tomas R monshi at home.se
Sat Mar 7 10:16:34 EST 2009
Thanks, it works. Just set the path.
Proj4 I think I will grab from your compilation. Should work good
enough. I will compile GDAL myself to keep it minimal. Only need the
Proj4 library as far as I know.
Sadly, it seems a straight upgrade from, 1.5 is not possible. That is,
my use of GDAL is to create a plugin to SportTracks making GDAL
available to other plugins. Plugins linked via csharp libraries to 1.5
version seems not to find the 1.6 version, they will need to be updated
to work.
That's just how it is I guess.
Thanks
/Tomas
Tamas Szekeres skrev:
> If you use my SDK just download and extract the proj4 package (eg.
> proj-4.6.1) within the SDK root directory and use:
> nmake proj PROJ_DIR=proj-4.6.1
> The Makefile will set the compiler version and the WIN64 setting
> seemlessly.
> It seems like the @SET FrameworkDir=Framework32  should point to the
> absolute path of the framework directory (ie
> C:\WINDOWS\Microsoft.NET\Framework) in your batch file.
> Best regards,
> Tamas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
