[gdal-dev] Re: Building 64 bit, Swig Error
Tamas Szekeres szekerest at gmail.com
Sat Mar 7 10:27:40 EST 2009
I think you'd just have to replace the reference to this version of
gdal_csharp.dll and recompile the project.
Best regards,
Tamas
2009/3/7 Tomas R <monshi at home.se>
> Thanks, it works. Just set the path.
> Proj4 I think I will grab from your compilation. Should work good enough. I
> will compile GDAL myself to keep it minimal. Only need the Proj4 library as
> far as I know.
> Sadly, it seems a straight upgrade from, 1.5 is not possible. That is, my
> use of GDAL is to create a plugin to SportTracks making GDAL available to
> other plugins. Plugins linked via csharp libraries to 1.5 version seems not
> to find the 1.6 version, they will need to be updated to work.
> That's just how it is I guess.
> Thanks
> /Tomas
> Tamas Szekeres skrev:
>> If you use my SDK just download and extract the proj4 package (eg.
>>  proj-4.6.1) within the SDK root directory and use:
>> nmake proj PROJ_DIR=proj-4.6.1
>> The Makefile will set the compiler version and the WIN64 setting
>> seemlessly.
>> It seems like the @SET FrameworkDir=Framework32  should point to the
>> absolute path of the framework directory (ie
>> C:\WINDOWS\Microsoft.NET\Framework) in your batch file.
>> Best regards,
>> Tamas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090307/b9f38348/attachment.html
