[gdal-dev] Buildig OpenEV with GDAL 1.6.0
Elias Luttinen
elias.luttinen at gmail.com
Sat Mar 14 15:16:47 EDT 2009
Did you type 'make install' after 'make' when installing the GDAL?
'make install' creates include and lib directories under --prefix,
which OpenEV configure is trying to find.
Br,
Elias
2009/1/30 Vali Poncos <vali_poncos at yahoo.ca>:
> Hi folks,
> I built GDAL 1.6.0 then I tried to build OpenEV. OpenEV seem to find GDAL
> but not GDALOpen. I checked Internet and I see that there is a GDALOpen.cpp
> file which it seems to be missing in the latest GDAL build. I found though
> the GDALOpen as a method in gdaldataset.cpp in version 1.6.0.
> What would be the problem here?
> Thanks,
> Vali
> configure: Found local
> GDAL_HOME=/media/Data/Work/K-SAR/openev_source/../gdal
> checking for GDALOpen in -lgdal... no
> checking for GDALOpen in -lgdal... (cached) no
> configure: error:
> OpenEV requires GDAL library, but it was not found. Please download
> and install it. See http://www.remotesensing.org/gdal
> ________________________________
> Looking for the perfect gift? Give the gift of Flickr!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
