[gdal-dev] How to use gdal DXF-Patch (Trac #2555)
saith at arcor.de saith at arcor.de
Tue Mar 17 04:15:38 EDT 2009
Hi list,
I tried to use the DXF-patch (http://trac.osgeo.org/gdal/ticket/2555) to get DXF-support in my gdal. Using the patchfile works fine. After this step I installed the dxflib and copied the lib-files into the new ogr/ogrsf_frmts/dxf folder. I used ./configure in the gdal-src folder with the --prefix - option, to install in a new directory. After make and make install gdal works fine, but without any DXF-support. Where is my mistake?
Thanks
Mathias Richter
Zerreißen Sie die Netze der Phisher, Hacker und Betrüger!
Ihre Internet-Sicherheits-Seiten auf Arcor.de bieten alle Infos und Hilfsmittel, die Sie zum sicheren Surfen brauchen! Play it safe!
http://www.arcor.de/footer-sicherheit/
