[gdal-dev] gdaltindex and netCDF files
Roger André
randre at gmail.com
Thu Mar 19 15:26:54 EDT 2009
Hi All,
Is it possible to use gdaltindex to create a shapefile index of a
group of netCDF files? Specifivally, I need to index a specific
netCDF variable that exists in all of the files. I just tried running
it on a single file, using the variable selection syntax that seems to
work with the other gdal utilities, but can't seem to make it work.
gdaltindex netcdf_index.shp
./NETCDF:"N35E115_5x5_19970101000000_20070102230000.ttnc":elev
ERROR 4: `./NETCDF:N35E115_5x5_19970101000000_20070102230000.ttnc:elev'
does not exist in the file system,
and is not recognised as a supported dataset name.
Unable to open ./NETCDF:N35E115_5x5_19970101000000_20070102230000.ttnc:elev,
skipping.
Thanks,
Roger
