[gdal-dev] gdal create tif, errors with gdaladdo
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 19 17:41:53 EDT 2009
I just created a bunch of tif files from a mrsid file and when I use
gdaladdo file.tif 2 4 8 16 32 64 128 256
I get over a 1000 errors like:
ERROR 1: n-41-25_0-0.tif:DumpModeDecode: Not enough data for scanline 1536
ERROR 1: TIFFReadEncodedTile() failed.
ERROR 1: IReadBlock failed at X offset 12, Y offset 7
ERROR 1: GetBlockRef failed at X block offset 12, Y block offset 7
ERROR 1: n-41-25_0-0.tif:DumpModeDecode: Not enough data for scanline 1664
ERROR 1: IReadBlock failed at X offset 13, Y offset 7
ERROR 1: GetBlockRef failed at X block offset 13, Y block offset 7
Is this because of the number of overviews I requested? ot something
else? Is it safe to ignore these?
-Steve
