[gdal-dev] Re: gdal_fillnodata error
Vincent Schut schut at sarvision.nl
Fri Mar 27 05:31:53 EDT 2009
Wesley Roberts wrote:
> Hi Vincent and List,
> You are correct, the library was not in my path and the command you
> suggested worked perfectly. I think the problem lies in the number of
> versions of gdal I have installed on my machine. I have a recently
> downloaded svn version of gdal, gdal 1.5.2 and gdal 1.4.4. Version 1.4.4
> was installed using synaptic (Ubuntu Hardy Heron), the svn version and
> 1.5.2 are both local installs compiled from source. gdal_translate etc
> all find their libraries from the synaptic version (I tried to find
> these but could not??) while FillNoData now gets its libraries from a
> local install. Managing the different versions is perhaps the source of
> my problem. I am in the process of learning to use OTB which requires
> gdal 1.5.2
Note that current versions of OTB from their hg repostitory *do* work
for me with svn gdal (need to do a clean ccmake and build for OTB
though, ccmake will pick up your gdal alright and for me the previous
errors are gone). That might save you one extra gdal version on your
system...
Vincent.
