[gdal-dev] Re: gdal_fillnodata error
Wesley Roberts
wroberts at csir.co.za
Fri Mar 27 04:52:24 EDT 2009
Hi Vincent and List,
You are correct, the library was not in my path and the command you
suggested worked perfectly. I think the problem lies in the number of
versions of gdal I have installed on my machine. I have a recently
downloaded svn version of gdal, gdal 1.5.2 and gdal 1.4.4. Version 1.4.4
was installed using synaptic (Ubuntu Hardy Heron), the svn version and
1.5.2 are both local installs compiled from source. gdal_translate etc
all find their libraries from the synaptic version (I tried to find
these but could not??) while FillNoData now gets its libraries from a
local install. Managing the different versions is perhaps the source of
my problem. I am in the process of learning to use OTB which requires
gdal 1.5.2 and I downloaded the svn version of gdal for the original
gdal_fillnodata which I could not get going, hence my previous mail
regarding that. So yes, perhaps I need to manage my installs a bit
better.
Having said all this I now get a segmentation fault when I run the
prog... will investigate to see what the problem is
Many thanks to Brent and Vincent for your help, much appreciated
Wesley
Wesley Roberts MSc.
Researcher: Earth Observation (Ecosystems)
Natural Resources and the Environment
CSIR
Tel: +27 (21) 888-2490
Fax: +27 (21) 888-2693
"To know the road ahead, ask those coming back."
- Chinese proverb
>>> Vincent Schut <schut at sarvision.nl> 03/27/09 9:46 AM >>>
Wesley Roberts wrote:
> Dear list,
> Sometime last week I posted a question regarding errors associated
with
> gdal_fillnodata. Brent Fraser kindly shared with me some C++ code he
had
> written to approximate the workings of the python gdal_fillnodata app.
> Through trial and error (and some extra help from Brent) I have
finally
> gotten the code to work and compile using the following command
> wroberts at wroberts-desktop:/usr/local/gdal/include$ sudo g++
> -I/usr/include/gdal gdal_FillNoData.cpp -L/usr/local/gdal/lib -lgdal
-o
> FillNoData
> unfortunately once compiled I try to run it for usage info and I get
the
> following error
> wroberts at wroberts-desktop:/usr/local/gdal/include$ ./FillNoData
> ./FillNoData: error while loading shared libraries: libgdal.so.1:
cannot
> open shared object file: No such file or directory
> I am a little lost as the file libgdal.so.1 is located in
> wroberts at wroberts-desktop:/usr/local/gdal/lib$ ls -l
> total 64212
> -rw-r--r-- 1 root root 40876082 2009-03-17 10:09 libgdal.a
> -rwxr-xr-x 1 root root 1393 2009-03-17 10:09 libgdal.la
> lrwxrwxrwx 1 root root 17 2009-03-17 10:09 libgdal.so ->
> libgdal.so.1.13.0
> lrwxrwxrwx 1 root root 17 2009-03-17 10:09 libgdal.so.1 ->
> libgdal.so.1.13.0
> -rwxr-xr-x 1 root root 24795259 2009-03-17 10:09 libgdal.so.1.13.0
> I now see that libgdal.so.1 is infact a link to another file.
> Unfortunately I have done a 'find' for libgdal.so.1 and have tried
many
> combinations of paths to gdal lib folders and this is the only one
that
> actually compiles.
Hi Wesley,
it being a link is fine. First thing to check is if this directory
'/usr/local/gdal/libs' is in your library search path. Check it by
running your program as follows:
LD_LIBRARY_PATH=/usr/local/gdal/lib ./FillNoData
If this does not give you this error, the problem is your lib search
path (I wonder however how your other gdal utilities, think
gdal_translate etc. *do* find this lib then???). To add a directory to
your system's lib search path permanently, you can (as root) add it to
the file /etc/ld.so.conf. For a less permanent solution you could export
it from your ~/.bashrc I think.
If it still does not work, please report back to the list.
Regards,
Vincent.
> I would like to use the app to fill the gaps in Landsat ETM+ data
> (SLC-off).
> Does anyone on the list have ideas with regards to finding a solution
to
> my problem? Any help would be greatly appreciated.
> Kind regards,
> Wesley
>>>> Brent Fraser <bfraser at geoanalytic.com> 03/26/09 4:38 P> steps to creating an executable:
> 1. The compile step. gcc needs to be able to find any "include" files
> referenced in the source code. You've somewhat solved this by
compiling
> in the GDAL include directory. You may want to look into how specify
> additional include directories on the gcc command line (a -I option?).
> 2. The link step. gcc needs to be able to find compiled libraries of
> functions referenced in the c++ code. This is the problem you've
shown
> below. You need to specify the GDAL library on the gcc command line;
> something like:
> g++ gdal_FillNoData.cpp -L../lib -lgdal -o fill_no_data
> I found
http://www.network-theory.co.uk/docs/gccintro/gccintro_17.html
> to be a good gcc intro. And Frank Warmerdam gave some insight in
> http://n2.nabble.com/gdal_priv.h-not-found-on-ubuntu-td2035784.html
> Best Regards,
> Brent Fraser
>> Hi Brent,
>> Many thanks for your code and apologies for not replying sooner,
> things
>> have been a little busy here. As you mentioned in your mail the code
> may
>> need some tweaking, I received some
>> warning: deprecated conversion from string constant to ‘char
>> errors but have managed to sort those out through trial and error. I
>> also had trouble with the include files so am now compiling from
> inside
>> the gdal directory on usr/local/gdal/include. This is something I
will
>> remedy later on, for now I am receiving the following errors and
given
>> my inexperience using c++ I am not able to correct the code. Could
you
>> please help me? Error is below.
>> Many thanks,
>> Wesley
>> gdal_FillNoData.cpp -o fill_no_data
>> /tmp/ccz4jVWn.o: In function `ga_CopyBand(void*, void*, int, int)':
>> gdal_FillNoData.cpp:(.text+0x14b): undefined reference to
>> `GDALGetBlockSize'
>> gdal_FillNoData.cpp:(.text+0x156): undefined reference to
>> `GDALGetRasterDataType'
>> gdal_FillNoData.cpp:(.text+0x164): undefined reference to
>> `GDALGetDataTypeSize'
>> gdal_FillNoData.cpp:(.text+0x241): undefined reference to
> `GDALRasterIO'
>> gdal_FillNoData.cpp:(.text+0x29c): undefined referen>
gdal_FillNoData.cpp:(.text+0x2e0): undefined reference to
>> `GDALGetGeoTransform'
>> gdal_FillNoData.cpp:(.text+0x2fb): undefined reference to
>> `GDALSetGeoTransform'
>> gdal_FillNoData.cpp:(.text+0x306): undefined reference to
>> `GDALGetProjectionRef'
>> gdal_FillNoData.cpp:(.text+0x315): undefined reference to
>> `GDALSetProjection'
>> /tmp/ccz4jVWn.o: In function `ga_World2Image(double, double, double*,
>> long*, long*)':
>> gdal_FillNoData.cpp:(.text+0x38b): undefined reference to
>> `GDALInvGeoTransform'
>> gdal_FillNoData.cpp:(.text+0x3b2): undefined reference to
>> `GDALApplyGeoTransform'
>> /tmp/ccz4jVWn.o: In function `ga_Image2World(long, long, double*,
>> double*, double*)':
>> gdal_FillNoData.cpp:(.text+0x467): undefined reference to
>> /tmp/ccz4jVWn.o: In function `app_version(_IO_FILE*)':
>> gdal_FillNoData.cpp:(.text+0x4c1): undefined reference to
>> `GDALVersionInfo'
>> /tmp/ccz4jVWn.o: In function `main':
>> gdal_FillNoData.cpp:(.text+0x66d): undefined reference to
>> `GDALTermProgress'
>> gdal_FillNoData.cpp:(.text+0x6c8): undefined reference to
>> `GDALAllRegister'
>> gdal_FillNoData.cpp:(.text+0x6e7): undefined reference to
>> `GDALGeneralCmdLineProcessor'
>> gdal_FillNoData.cpp:(.text+0x7bc): undefined reference to
> `CSLAddString'
>> gdal_FillNoData.cpp:(.text+0x7f2): undefined reference to
>> `GDALDummyProgress'
>> gdal_FillNoData.cpp:(.text+0x99d): undefined reference to
>> `GDALDestroyDriverManager'
>> gdal_FillNoData.cpp:(.text+0xa0e): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xa47): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xa6c): undefined ref>> gdal_FillNoData.cpp:(.text+0xa92): undefined reference to
>> `CPLGetLastErrorMsg'
>> gdal_FillNoData.cpp:(.text+0xa99): undefined reference to
>> `CPLGetLastErrorNo'
>> gdal_FillNoData.cpp:(.text+0xabc): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xad3): undefined reference to
>> `GDALGetRasterXSize'
>> gdal_FillNoData.cpp:(.text+0xae1): undefined reference to
>> `GDALGetRasterYSize'
>> gdal_FillNoData.cpp:(.text+0xb0f): undefined reference to
>> `GDALGetRasterCount'
>> gdal_FillNoData.cpp:(.text+0xb74): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xb92): undefined reference to
>> `GDALGetRasterBand'
>> gdal_FillNoData.cpp:(.text+0xba0): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xbcf): undefined reference to
>> `GDALGetMaskBand'
>> gdal_FillNoData.cpp:(.text+0xbe7): undefined reference to
>> `GDALOpenShared'
>> gdal_FillNoData.cpp:(.text+0xc03): undefined reference to
>> `GDALGetRasterBand'
>> gdal_FillNoData.cpp:(.text+0xc0d): undefined reference to
>> `CPLGetLasgdal_FillNoData.cpp:(.text+0xc37): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xc66): undefined reference to
>> `GDALGetDriverByName'
>> gdal_FillNoData.cpp:(.text+0xc74): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xc7b): undefined reference to
>> `CPLGetLastErrorNo'
>> gdal_FillNoData.cpp:(.text+0xc9e): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xce0): undefined reference to
`GDALCreate'
>> gdal_FillNoData.cpp:(.text+0xcee): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xcf5): undefined reference to
>> `CPLGetLastErrorNo'
>> gdal_FillNoData.cpp:(.text+0xd18): undefined reference to
>> gdal_FillNoData.cpp:(.text+0xd49): undefined reference to
>> `GDALGetRasterBand'
>> gdal_FillNoData.cpp:(.text+0xd85): undefined reference to
>> `GDALGetRasterNoDataValue'
>> gdal_FillNoData.cpp:(.text+0xd94): undefined reference to
>> `GDALSetRasterNoDataValue'
>> gdal_FillNoData.cpp:(.text+0xdd3): undefined reference to
>> `GDALFillNodata'
>> gdal_FillNoData.cpp:(.text+0xdde): undefined referenc>
gdal_FillNoData.cpp:(.text+0xe00): undefined reference to `GDALClose'
>> gdal_FillNoData.cpp:(.text+0xe1a): undefined reference to
>> `GDALTermProgress'
>> collect2: ld returned 1 exit status
>>>>> Brent Fraser <bfraser at geoanalytic.com> 03/18/09 11:40 PM >>>
>> Wesley,
>> I had the same problem when dealing with DEMs over the last few
> days.
>> I don't know enough about python to make it work, so I coded
>> gdal_fillnodata in c++ (ish). See attached file. This is barely
>> debugged, so it may need some fixes to work for you.
>> Brent Fraser
>> GeoAnalytic Inc.
>>> Dear List,
>>> Yesterday I did an install of the latest svn gdal release (think it
> is
>> 1.7) to my local machine. I am interested in using the
>> gdal_fillnodata.py application to fill some lines in my Landsat 7 ETM
>> data. When I run the code
>>> python gdal_fillnodata.py -md 400
/home/wroberts/wes2006/Projects/Evapotranspiration/Data/Landsat_NDVI/test.img
/home/wroberts/wes2006/Projects/Evapotranspiration/Data/Landsat_NDVI/test.fill.img
>>> I get the following error
>>> gdal.FillNodata() not available. You are likely using "old gen"
>>> bindings or an older version of the next gen bindings.
>>> I am not sure what this means, could somebody suggest a solution or
>> work around. I am currently trying r.fillnulls in Grass and that is
>> taking a really long time.
>>> Many thanks for your help and input,
>>> Wesley
>>> Wesley Roberts MSc.
>>> CSIR
>>> Tel>>> - Chinese proverb
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
