[gdal-dev] ogr2ogr C#
Even Rouault
even.rouault at mines-paris.org
Fri Mar 27 15:01:04 EDT 2009
Note I've ported ogr2ogr to the Java bindings, so I guess it should be
relatively easy to port it to C# as both languages are pretty close.
Porting it from C++ to Java was rather straighforward (but very boring!).
Replace NULL by null, TRUE by true, FALSE by false, -> by ., printf by
System.out.println etc...
See :
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java/apps/ogr2ogr.java
Le Friday 27 March 2009 08:46:22 Sune Dogan, LIFA A/S, vous avez écrit :
> Hi
> Im developing a .NET C# project and need to convert from GML to ESRI
> Shape
> Simply i want to run this command:
> ogr2ogr -skipfailures -f "ESRI Shapefile" C:\shapefile.shp
> c:\gmlfile.gml
> which works fine from the FWTool Command tool.
> But i just want to do i in my application, can any one help me?
> Thanks :)
