[gdal-dev] How to use GDAL Library
Ajmeri Iqbal isajmeri at rediffmail.com
Fri Mar 27 10:11:20 EDT 2009
Hi Benoît Andrieu,Thanks for reply.i already saw that tutorial,but the problame is how to and which library to be linked using QT(most probably same way of C/C++).coz there is a three library named gdal16.dll, gdal_i.lib and gdal.lib.On Fri, 27 Mar 2009 11:33:42 +0100 Benoît Andrieu wroteHi, If you want to use GDAL in C / C++, take a look at the tutorial at http://www.gdal.org/gdal_tutorial.html.It is really straightforward, I used this for the integration of GDAL in our modules and it worked fine. Regards, Benoît Andrieubea at ixsea.combenoit.andrieu@gmail.com----- Original Message ----- From: Ajmeri Iqbal To: gdal-dev at lists.osgeo.org Sent: Friday, March 27, 2009 11:06 AMSubject: [gdal-dev] How to use GDAL LibraryDear all,I want to use GDAL library in my project using QT.How could i use this library for Reading and writing the Raster images (i.e. JPEG,JPEG200,TIFF,GeoTiff,BMP,PNG,GIF, etc)please help me.Thanks in advance_______________________________________________gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090327/55360a21/attachment.html
