[gdal-dev] How to use GDAL Library
Benoît Andrieu bea at ixsea.com
Fri Mar 27 13:54:01 EDT 2009
I am using FWTools 2.2.9
So I am releasing my softwares with most of the dlls (you can use depends to find which).
The linking is done with :
gdal_i.lib
geos_i.lib
geotiff_i.lib
libtiff_i.lib
proj_i.lib
But yo may want to use more or less libraries...
Regards,
Benoît Andrieu
bea at ixsea.com
benoit.andrieu at gmail.com
  ----- Original Message -----
  To: bea at ixsea.com
  Cc: gdal-dev at lists.osgeo.org
  Sent: Friday, March 27, 2009 3:11 PM
  Subject: Re :Re: [gdal-dev] How to use GDAL Library
  Hi Benoît Andrieu,
  Thanks for reply.
  i already saw that tutorial,
  but the problame is how to and which library to be linked using QT(most probably same way of C/C++).
  coz there is a three library named gdal16.dll, gdal_i.lib and gdal.lib.
  On Fri, 27 Mar 2009 11:33:42 +0100 Benoît Andrieu wrote
  If you want to use GDAL in C / C++, take a look at
  the tutorial at http://www.gdal.org/gdal_tutorial.html.
  It is really straightforward, I used this for the
  integration of GDAL in our modules and it worked fine.
  Regards,
  Benoît Andrieubea at ixsea.combenoit.andrieu@gmail.com
  Ajmeri
  Iqbal
  To: gdal-dev at lists.osgeo.org
  Sent: Friday, March 27, 2009 11:06
  AM
  Subject: [gdal-dev] How to use GDAL
  Library
  Dear all,I want to use GDAL library in my project using
  QT.How could i use this library for Reading and writing the Raster images
  (i.e. JPEG,JPEG200,TIFF,GeoTiff,BMP,PNG,GIF, etc)please help
  me.Thanks in advance
  _______________________________________________gdal-dev mailing
  listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090327/df01911e/attachment-0001.html
