[Gdal-dev] SWIG bindings in Linux
Tamas Szekeres
szekerest at gmail.com
Sat Mar 28 06:28:20 EDT 2009
Hi Frank,
I've got your build outputs but I still didn't have the chance to inspect
the issue in more detail. I'll get back to you with further information
shortly.
I just wanted to mention thet the buildbot didn't require to have elevated
privileges to build gdal and the SWIG bindings, however some prerequisites
have already been pre-installed on the system.
I've also found issues with some of the recent MONO libraries causing
unexpected segfaults in the applications.
Best regards,
Tamas
2009/3/27 turtlewax <fevans at harris.com>
> In the past I've opened threads on GDAL/Mono. This may have been too
> specific, so I'd like to rephrase the topic to include GDAL SWIG bindings
> for any language in Linux.
> Just looking for feedback. Has anyone succeeded in getting the bindings to
> work in Linux? I realize the buildbots generate bindings, but has anyone
> else succeeded in compiling/using them?
> What configure command was used?
> What are the minimal dependencies? xerces, curl?
> What compiler/linker flags were used?
> I'm in a situation where I don't have root, so I'm forced to use a prefix
> for anything I compile/install. Thus far I've gotten a lot of SWIG projects
> to work in Linux, but have it a wall with gdal.
> Thanks in advance.
> http://n2.nabble.com/SWIG-bindings-in-Linux-tp2546587p2546587.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090328/65fc1a2c/attachment-0001.html
