[gdal-dev] How to use GDAL Library
Benoît Andrieu
bea at ixsea.com
Mon Mar 30 08:42:07 EDT 2009
Hi !
You won't need any cpp files.
Personally, I am using the FWTools package which bundles dll, libs and headers files.
You just have to compile using gdal_priv.h
Then link to gdal_i.lib
Then provide with your runtime all the dlls which gdal_fw.dll is depending to.
You will find which dlls it is depending to by using Dependency Walker (http://www.dependencywalker.com/).
Then your runtime will be able to use all of the image formats drivers that GDAL was compiled to support.
I hope this will help.
Regards,
Benoît Andrieu
bea at ixsea.com
benoit.andrieu at gmail.com
----- Original Message -----
To: bea at ixsea.com
Cc: gdal-dev at lists.osgeo.org
Sent: Monday, March 30, 2009 11:06 AM
Subject: Re :Re: Re :Re: [gdal-dev] How to use GDAL Library
Actually i m working on Generic image reading/writing and display on viewer with all of its information, so i think i need all listed library. but dont know how to use them in my code.
i have downloded gdal_i.lib, gdal.dll and its include .h files.
.h files contains only the prototype function to link with library but i could not find its .cpp file which may containt implementation function of that linking function of .h files.
can u please give me broad idea or step by step procedure about how do i link these library to c++ code.
thanks in advance
Regards,
Iqbal
On Fri, 27 Mar 2009 18:54:01 +0100 Benoît Andrieu wrote
I am using FWTools 2.2.9
So I am releasing my softwares with most of the
dlls (you can use depends to find which).
The linking is done with :
gdal_i.libgeos_i.libgeotiff_i.liblibtiff_i.libproj_i.lib
But yo may want to use more or less
libraries...
Regards,
Benoît Andrieubea at ixsea.combenoit.andrieu@gmail.com
Ajmeri
Iqbal
Sent: Friday, March 27, 2009 3:11
PM
Subject: Re :Re: [gdal-dev] How to use
GDAL Library
Hi Benoît Andrieu,Thanks for reply.i already saw that
tutorial,but the problame is how to and which library to be linked using
QT(most probably same way of C/C++).coz there is a three library named
gdal16.dll, gdal_i.lib and gdal.lib.On Fri, 27 Mar 2009 11:33:42
+0100 Benoît Andrieu wroteHi, If
you want to use GDAL in C / C++, take a look at the tutorial at http://www.gdal.org/gdal_tutorial.html.It
is really straightforward, I used this for the integration of GDAL in our
modules and it worked fine. Regards, Benoît
Andrieubea at ixsea.combenoit.andrieu@gmail.com----- Original Message
Sent: Friday, March 27, 2009 11:06 AMSubject: [gdal-dev] How to
use GDAL LibraryDear all,I want to use GDAL library in my project
using QT.How could i use this library for Reading and writing the Raster
images (i.e. JPEG,JPEG200,TIFF,GeoTiff,BMP,PNG,GIF, etc)please help
me.Thanks in
advance_______________________________________________gdal-dev
mailing
listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090330/190999c3/attachment.html
