Re: [gdal-dev] Converting big Intergraph cit files
Lucena, Ivan
ivan.lucena at pmldnet.com
Wed May 6 10:01:38 EDT 2009
Andreas,
If that issue is related to http://trac.osgeo.org/gdal/ticket/1959 check the version you are using.
Ivan
> -------Original Message-------
> From: Andreas Neumann <a.neumann at carto.net>
> Subject: [gdal-dev] Converting big Intergraph cit files
> Sent: May 06 '09 01:58
> Hi all,
> I am trying to convert Intergraph cit files. While it works perfectly fine
> for medium-size cit files it fails for bigger cit files. I get the
> following error message:
> user at server:/home/www/mapserverdata/lk_alt$ gdal_translate -of GTiff
> -a_srs EPSG:21781 -a_nodata 0 -co 'TFW=YES' -co 'COMPRESS=PACKBITS' -co
> 'NBITS=1' /home/an/server/geonis/UsterAV01/LK_Raster/B_Kirchuster/b04.cit
> b04.tif
> Input file size is 46368, 46368
> 0ERROR 6: Too big block : 46368 * 46368
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
> Files with sizes below 30000 x 30000 pixels convert fine.
> I know, those eccentric Intergraph raster files are going to die/fade
> away, anyway - that's why I want to convert them to something more
> mainstream ...
> Is there any compile-time switch or a commandline option I could use to
> work around the problem with bigger cit files?
> http://www.gdal.org/frmt_intergraphraster.html doesn't list any size
> limitations with the intergraph drivers.
> Thanks,
> Andreas
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
