[gdal-dev] Converting big Intergraph cit files
Andreas Neumann
a.neumann at carto.net
Wed May 6 10:26:18 EDT 2009
Thanks, Lucena.
This seems to the issue. I am using 1.6.0 (not trunk). Meanwhile I was
able to solve the issue with nconvert (xnview) as a workaround.
Thanks,
Andreas
On Wed, May 6, 2009 4:01 pm, Lucena, Ivan wrote:
> Andreas,
> If that issue is related to http://trac.osgeo.org/gdal/ticket/1959 check
> the version you are using.
> Ivan
>> -------Original Message-------
>> From: Andreas Neumann <a.neumann at carto.net>
>> Subject: [gdal-dev] Converting big Intergraph cit files
>> Sent: May 06 '09 01:58
>> Hi all,
>> I am trying to convert Intergraph cit files. While it works perfectly
>> fine
>> for medium-size cit files it fails for bigger cit files. I get the
>> following error message:
>> user at server:/home/www/mapserverdata/lk_alt$ gdal_translate -of GTiff
>> -a_srs EPSG:21781 -a_nodata 0 -co 'TFW=YES' -co 'COMPRESS=PACKBITS' -co
>> 'NBITS=1'
>> /home/an/server/geonis/UsterAV01/LK_Raster/B_Kirchuster/b04.cit
>> b04.tif
>> Input file size is 46368, 46368
>> 0ERROR 6: Too big block : 46368 * 46368
>> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
>> Files with sizes below 30000 x 30000 pixels convert fine.
>> I know, those eccentric Intergraph raster files are going to die/fade
>> away, anyway - that's why I want to convert them to something more
>> mainstream ...
>> Is there any compile-time switch or a commandline option I could use to
>> work around the problem with bigger cit files?
>> http://www.gdal.org/frmt_intergraphraster.html doesn't list any size
>> limitations with the intergraph drivers.
>> Thanks,
>> Andreas
>> Andreas Neumann
>> http://www.carto.net/neumann/
>> http://www.svgopen.org/
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Andreas Neumann
