[gdal-dev] reading NOAA coastwatch hdf using GDAL
yehya imam
yehya_imam at yahoo.com
Thu May 21 06:52:38 EDT 2009
Dear GDALers,
I'm trying to read CoastWatch HDF files in GRASS GIS. These files can be downloaded from NOAA CLASS at http://www.class.ncdc.noaa.gov/saa/products/welcome.
I could not read the files directly into GRASS and have thought to extract just the SST channel (dataset) from the hdf into a gtif that is readable by GRASS.
Have someone on this list used the GDAL utilities to manipulate CW-hdf files (warp and export one band into tif with full projection info)? The affine transformation coeffs, included in the metadata, seems to be unreachable by GDAL utils.
Regards,
Yehya
__________________________________________________________________
Get the name you've always wanted @ymail.com or @rocketmail.com! Go to http://ca.promos.yahoo.com/jacko/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090521/cc615d15/attachment.html
