Re: [gdal-dev] VC++(msvc2005) and GDAL
Ivan ivan.lucena at pmldnet.com
Thu Nov 5 09:00:49 EST 2009
Wei,
Your VC++ project would need to see the GDAL include and GDAL lib folder; it should need to link with the "gdal_i.lib"; and at run time it will requires GDAL bin folder to be on the Windows path variable.
You can get the GDAL Dev distribution by compiling GDAL from the source code, from OSGeo4w or downloading the zip package. But if you compile from the source code, remember to run "nmake -f makefile.vc *devinstall*". That will setup all the folders that I mentioned before.
Regards,
Ivan
>  -------Original Message-------
>  From: weixj2003ld <weixj2003ld at 163.com>
>  Subject: [gdal-dev] VC++(msvc2005) and GDAL
>  Sent: Nov 05 '09 01:16
>  Hi,
>  I am a newer to GDAL.
>  How to embed GDAL into VC++,that is,I want to create frame with MFC,and
>  GDAL only read/write Raster data?Thank you in advance.
>  Wei
>  [LINK:
>  http://allyes.nie.163.com/main/adfclick?db=afanie&bid=1256,612,23&cid=146,4,1&sid=1353&show=ignore&url=http://tx2.163.com/fab.html]
>   3D
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
