[gdal-dev] Re: gdal to define projection, EPSG:3412
Hermann Peifer peifer at gmx.eu
Thu Nov 12 12:43:23 EST 2009
John,
I guess you are right:  "+lat_0=-90" shouldn't result into
"PARAMETER["latitude_of_origin",-70]". There seems to be some parameter
confusion.
It also looks like
http://spatialreference.org/ref/epsg/3412/prettywkt/ would be wrong in
this case.
EPSG guidance notes 7.2 describe polar stereographic projection with
variants A, B and C... I am not the ultimate expert here. It might be
worth to ask for clarification in the proj mailing list.
Hermann
John Callahan wrote:
> Thanks Frank/Hermann for your responses.  However, something odd seems
> to be going on here. I feel like I'm missing something on how GDAL
> handles coordinate system information.
> Using the same input data set, and converting to different formats, the
> description of the output coordinate systems are different. Is this
> expected?   Here are the gdal_translate commands and their respective
> output files gdalinfo descriptions below.
> [1] gdal_translate -a_srs "+proj=stere +lat_0=-90 +lat_ts=-70 +lon_0=0
> +k=1 +x_0=0 +y_0=0 +a=6378273 +b=6356889.449 +units=m +no_defs" -of
> GTiff nt_200712_f13_v01_s.bsq nsidc_test.tif
> [2] gdal_translate -a_srs "+proj=stere +lat_0=-90 +lat_ts=-70 +lon_0=0
> +k=1 +x_0=0 +y_0=0 +a=6378273 +b=6356889.449 +units=m +no_defs" -of HFA
> nt_200712_f13_v01_s.bsq nsidc_test.img
> [3] gdal_translate -a_srs "+proj=stere +lat_0=-90 +lat_ts=-70 +lon_0=0
> HDF4Image nt_200712_f13_v01_s.bsq nsidc_test.hdf
> [4] gdal_translate -a_srs EPSG:3412 -of GTiff nt_200712_f13_v01_s.bsq
> nsidc_test_epsg.tif
> [5] gdal_translate -a_srs EPSG:3412 -of HFA nt_200712_f13_v01_s.bsq
> nsidc_test_epsg.img
> Fortunately, I can display these images fine.  They overlay nicely in
> QGIS with some vector data I have.   However, the problem occurs when
> projecting to EPSG:4326 (or similar) coordinate system; the output files
> are incorrect/missing data.  (It displays data from roughly lat -39.25
> only down to roughly -54.75 when data exists all the way down to -90.)
> One possible cause could be that gdalinfo reports (for all of these
> datasets) latitude_of_origin as -70.  From
> http://nsidc.org/data/atlas/epsg_3412.html, the latitude of origin
> should be -90 and the latitude of standard parallel should be -70.  Or
> the problem could be somewhere in gdalwarp, or specifically with the
> Hughes 1980 ellipsoid.  I have no idea.  Thanks.
> - John
> [1] Driver: GTiff/GeoTIFF
> Files: nsidc_test.tif
> Size is 316, 332
> Coordinate System is:
> PROJCS["unnamed",
>    GEOGCS["unnamed ellipse",
>        DATUM["unknown",
>            SPHEROID["unnamed",6378273,298.279411123061]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433]],
>    PROJECTION["Polar_Stereographic"],
>    PARAMETER["latitude_of_origin",-70],
>    PARAMETER["central_meridian",0],
>    PARAMETER["scale_factor",1],
>    PARAMETER["false_easting",0],
>    PARAMETER["false_northing",0],
>    UNIT["metre",1,
>        AUTHORITY["EPSG","9001"]]]
> Origin = (-3950000.000000000000000,4350000.000000000000000)
> Pixel Size = (25000.000000000000000,-25000.000000000000000)
> Metadata:
>  AREA_OR_POINT=Area
> Image Structure Metadata:
>  INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (-3950000.000, 4350000.000) ( 42d14'27.21"W, 39d13'51.20"S)
> Lower Left  (-3950000.000,-3950000.000) (135d 0'0.00"W, 41d26'49.04"S)
> Upper Right ( 3950000.000, 4350000.000) ( 42d14'27.21"E, 39d13'51.20"S)
> Lower Right ( 3950000.000,-3950000.000) (135d 0'0.00"E, 41d26'49.04"S)
> Center      (       0.000,  200000.000) (  0d 0'0.01"E, 88d 9'14.17"S)
> Band 1 Block=316x25 Type=Byte, ColorInterp=Gray
> [2] Driver: HFA/Erdas Imagine Images (.img)
> Files: nsidc_test.img
> Size is 316, 332
> PROJCS["Stereographic_South_Pole",
>    GEOGCS["GCS_unnamed ellipse",
>        DATUM["unknown",
>            SPHEROID["Unknown",6378273,298.279411123061]],
>        UNIT["Degree",0.017453292519943295]],
>    UNIT["Meter",1]]
> Corner Coordinates:
> Band 1 Block=64x64 Type=Byte, ColorInterp=Undefined
>  Metadata:
>    LAYER_TYPE=athematic
> [3] Driver: HDF4Image/HDF4 Dataset
> Files: nsidc_test.hdf
> Size is 316, 332
> PROJCS["unnamed",
>        DATUM["unknown",
>    UNIT["Meter",1]]
> Metadata:
>  Signature=Created with GDAL (http://www.remotesensing.org/gdal/)
>  TransformationMatrix=-3950000.000000, 25000.000000, 0.000000,
> 4350000.000000, 0.000000, -25000.000000
>  Projection=PROJCS["unnamed",GEOGCS["unnamed
> ellipse",DATUM["unknown",SPHEROID["unnamed",6378273,298.279411123061]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Polar_Stereographic"],PARAMETER["latitude_of_origin",-70],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1]]
> Corner Coordinates:
> Band 1 Block=316x316 Type=Byte, ColorInterp=Gray
> [4] Driver: GTiff/GeoTIFF
> Files: nsidc_test_epsg.tif
> Size is 316, 332
> PROJCS["NSIDC Sea Ice Polar Stereographic South",
>    GEOGCS["Unspecified datum based upon the Hughes 1980 ellipsoid",
>        DATUM["Not_specified_based_on_Hughes_1980_ellipsoid",
>            SPHEROID["Hughes 1980",6378273,298.279411123061,
>                AUTHORITY["EPSG","7058"]],
>            AUTHORITY["EPSG","6054"]],
>        UNIT["degree",0.0174532925199433],
>        AUTHORITY["EPSG","4054"]],
>    UNIT["metre",1,
>        AUTHORITY["EPSG","9001"]],
>    AUTHORITY["EPSG","3412"]]
> Metadata:
>  AREA_OR_POINT=Area
>  INTERLEAVE=BAND
> Corner Coordinates:
> [5] Driver: HFA/Erdas Imagine Images (.img)
> Files: nsidc_test_epsg.img
> Size is 316, 332
> PROJCS["NSIDC_Sea_Ice_Polar_Stereographic_South",
>    GEOGCS["GCS_Unspecified datum based upon the Hughes 1980 ellipsoid",
>        DATUM["Hungarian_Datum_1909",
>            SPHEROID["Hughes_1980",6378273,298.279411123061]],
>    UNIT["Meter",1]]
> Corner Coordinates:
>  Metadata:
> Frank Warmerdam wrote:
>>>> Thanks for responding Hermann. Yes, I tried using -s_srs EPSG:3412
>>>> as well as the full PROJ4 string with the same result. When
>>>> specifying -s_srs, does gdalwarp ignore (override) the project
>>>> information in the hdr file?
>>> Hmm. AFAIK: gdal_translate -a_srs does override the file's projection
>>> information. I have a random.tif in LAEA projection (EPSG:3035), so I
>>> tried the following with gdal 1.6.2:
>>> gdal_translate random.tif out1.tif -a_srs EPSG:3412  # this results
>>> in [1]
>>> gdal_translate random.tif out2.tif -a_srs "+proj=stere +lat_0=-90
>>> +lat_ts=-70 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378273 +b=6356889.449
>>> +units=m +no_defs"  # this gives [2]
>>> To me as an innocent GDAL user, this behaviour looks similar to
>>> http://trac.osgeo.org/gdal/ticket/3016. I might be wrong, though, in
>>> particular as you wrote that using the PROJ.4 string didn't help (and
>>> your source file isn't a GeoTIFF in the first place).
>> Hermann,
>> I have confirmed this problem and filed it as:
>>   http://trac.osgeo.org/gdal/ticket/3220
>> It is presumably a problem with translation of a specific projection
>> method,
>> possibly in libgeotiff itself.
>> Best regards,
