[gdal-dev] Re: gdal to define projection, EPSG:3412
John Callahan john.callahan at UDel.Edu
Thu Nov 12 16:18:10 EST 2009
Thank you Frank.  I hadn't thought about file formats supporting
projections or not.  Typically, you think about the software or
algorithm not supporting a projection or coordinate system, not the
format itself.
- John
Frank Warmerdam wrote:
> John Callahan wrote:
>> Thanks Frank/Hermann for your responses.  However, something odd
>> seems to be going on here. I feel like I'm missing something on how
>> GDAL handles coordinate system information.
>> Using the same input data set, and converting to different formats,
>> the description of the output coordinate systems are different. Is
>> this expected?   Here are the gdal_translate commands and their
>> respective output files gdalinfo descriptions below.
> John,
> I think the key thing is that coordinate system encoding mechanisms
> tend to vary from file format to file format.  A few points of note:
>  o GeoTIFF has two general ways of encoding - one is to just embed
>    the EPSG PCS code for a whole coordinate system.  The other is
>    to encode the projection method along with the parameters.  You
>    will tend to get the first when specifying the coordinate system
>    with EPSG:n and the second when using PROJ.4 strings.
>  o Many geospatial formats have a particular way of representing
>    projections, and may not support all projection methods, preserving
>    datums, preserving names, etc.
>> [1] gdal_translate -a_srs "+proj=stere +lat_0=-90 +lat_ts=-70
>> +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378273 +b=6356889.449 +units=m
>> +no_defs" -of GTiff nt_200712_f13_v01_s.bsq nsidc_test.tif
>> [2] gdal_translate -a_srs "+proj=stere +lat_0=-90 +lat_ts=-70
>> +no_defs" -of HFA nt_200712_f13_v01_s.bsq nsidc_test.img
>> Fortunately, I can display these images fine.  They overlay nicely in
>> QGIS with some vector data I have.   However, the problem occurs when
>> projecting to EPSG:4326 (or similar) coordinate system; the output
>> files are incorrect/missing data.  (It displays data from roughly lat
>> -39.25 only down to roughly -54.75 when data exists all the way down
>> to -90.)
>> One possible cause could be that gdalinfo reports (for all of these
>> datasets) latitude_of_origin as -70.  From
>> http://nsidc.org/data/atlas/epsg_3412.html, the latitude of origin
>> should be -90 and the latitude of standard parallel should be -70.
>> Or the problem could be somewhere in gdalwarp, or specifically with
>> the Hughes 1980 ellipsoid.  I have no idea.  Thanks.
> It sounds like there may be another issues with regard to the latitude
> of origin in addition to the issue with GeoTIFF not working properly with
> 3412.  If you can isolate and file a ticket that might be helpful.
> I'm sorry I haven't been following some of the recent srs threads very
> closely.
> Best regards,
