[gdal-dev] GDAL installing about building openev
Frank Warmerdam
warmerdam at pobox.com
Sun Nov 15 10:39:37 EST 2009
On Sun, Nov 15, 2009 at 1:45 AM, Randy <randyqiuxy at hotmail.com> wrote:
> Hi list,
> when I "./configure..." the OpenEv,the error is as follows:
> configure: Using requested GDAL_HOME
> of /home/randyqiu/run-time/gdal-1.6.2
> checking for GDALOpen in -lgdal... no
> checking for GDALOpen in -lgdal... (cached) no
> configure: error:
> OpenEV requires GDAL library, but it was not found. Please download
> and install it. See http://www.remotesensing.org/gdal
> But I have install GDAL successfully and there are four files(bin
> include lib share)in the path "/home/randyqiu/run-time/gdal-1.6.2".
Randy,
I'm not clear on what GDAL related options you passed to
configure. You may find it helpful to open config.log in an
editor and look for GDALOpen, then examine that area
of the log for a more specific idea of why things failed.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
