[Gdal-dev] PROJ.4 EPSG:28992
TomvanTilburg tom.van.tilburg at gmail.com
Thu Nov 26 07:44:21 EST 2009
Hi list,
Got a bit more info on this, hope someone can help.
It appears that running "geom.Transform(coordTrans)" on GDAL 1.6.0 PY 2.6.4
linux doesn't give an error while running the same script with the same
shapefile on GDAL 1.6.1 PY 2.6.3 winxp does produce the error (hence my
confusion yesterday when I saw it running on 1.6.0).
Summary:
inSpatialRef = osr.SpatialReference()
inSpatialRef.ImportFromEPSG(28992)
outSpatialRef = osr.SpatialReference()
outSpatialRef.ImportFromEPSG(4326)
coordTrans = osr.CoordinateTransformation(inSpatialRef, outSpatialRef)
trows an error with
Anyone who can reproduce this?
I have a lot of data in Amserfoort coordinates that I'l like to transform
(in windows). Help would be greatly appreciated.
best regards,
 Tom
Frank Warmerdam wrote:
> Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> in PROJ version 4.6 the definition for the Dutch national grid
>> (EPSG:28992)
>> is missing the towgs84 parameters.
View this message in context: http://n2.nabble.com/PROJ-4-EPSG-28992-tp2033665p4070970.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
