[Gdal-dev] PROJ.4 EPSG:28992
Even Rouault even.rouault at mines-paris.org
Thu Nov 26 14:33:28 EST 2009
A few points to check that come to mind :
* Did you check that the proj.dll can be loaded by GDAL ? Check an error
message about it
* Is the GDAL_DATA environment variable correctly set ?
* If testepsg.exe is compiled (nmake /f makefile.vc testepsg.exe in apps
directory should do), try testepsg EPSG:28992
TomvanTilburg a écrit :
> Hi list,
> Got a bit more info on this, hope someone can help.
> It appears that running "geom.Transform(coordTrans)" on GDAL 1.6.0 PY 2.6.4
> linux doesn't give an error while running the same script with the same
> shapefile on GDAL 1.6.1 PY 2.6.3 winxp does produce the error (hence my
> confusion yesterday when I saw it running on 1.6.0).
> Summary:
> inSpatialRef = osr.SpatialReference()
> inSpatialRef.ImportFromEPSG(28992)
> outSpatialRef = osr.SpatialReference()
> outSpatialRef.ImportFromEPSG(4326)
> coordTrans = osr.CoordinateTransformation(inSpatialRef, outSpatialRef)
> trows an error with
> Anyone who can reproduce this?
> I have a lot of data in Amserfoort coordinates that I'l like to transform
> (in windows). Help would be greatly appreciated.
> best regards,
>  Tom
> Frank Warmerdam wrote:
>> Bart van den Eijnden (OSGIS) wrote:
>>> Hi list,
>>> in PROJ version 4.6 the definition for the Dutch national grid
>>> (EPSG:28992)
>>> is missing the towgs84 parameters.
