[gdal-dev] compiling GDAL with GEOS on Windows
Yilmaz Arslanoglu
yilmaz.arslanoglu at gmail.com
Thu Oct 1 13:55:39 EDT 2009
Hi Frank;
> Make sure you do a "nmake /f makefile.vc clean" after any change to
Thank you very much, actually I should have already thought this before :)
Now it runs quite OK.
> If you specify a point to OGRLayer::SetSpatialFilter() you should only
> get back features that intersect that point.
Then do you have an idea how the "intersect" would behave between
a line string and a point? (I would expect TRUE if the point lies on
any of the line string legs,
FALSE otherwise) I'm asking since DEPARE layer may also contain line
string features besides
polygon features. (or shouldn't this happen at all?)
On Thu, Oct 1, 2009 at 7:00 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Yilmaz Arslanoglu wrote:
>> Hi;
>> I am trying to build and install the GDAL library on Windows XP
>> using the following commands:
>> nmake /f makefile.vc install
>> nmake /f makefile.vc devinstall
>> In order to build with GEOS support, I uncommented the lines
>> in the "nmake.opt" as follows:
>> GEOS_DIR=C:\geos-3.1.1
>> GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers -DHAVE_GEOS
>> GEOS_LIB = $(GEOS_DIR)/source/geos_c_i.lib
>> However, I still get the same .dll and .lib files as if no GEOS
>> support was turned on
> Yilmaz,
> the nmake.opt file. The makefiles are not setup to force a full
> rebuild on changes to the nmake.opt file or sub-makefiles.
>> 2) I was also wondering whether OGR library provides a kind of nearest
>> neighbour finding facilities?
>> If not, does anybody know any library that could be integrated with
>> OGR for this purpose?
>> I plan to use it to find the n nearest sounding points (SOUNDG)
>> given a point, to make a prediction
>> about its depth.
> Nothing comes to mind to address this.
>> 3) Finally, is there any facility in OGR for querying a layer such that
>> it will only return the features on it, which contain a given
>> point as parameter?
>> Because I could not come up with an SQL statement to perform this task.
>> Actually I was planning to use this on the DEPARE (depth area) layer on
>> an S-57 file to find the depth area polygon that covers the given
>> point.
> get back features that intersect that point. Without GEOS you would get
> any feature whose bounding box contained that point but with GEOS the
> test should be more precise.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
