[gdal-dev] double delay getting feature count
Clay, Bruce
bclay at ball.com
Wed Oct 14 11:58:49 EDT 2009
I have tried several different arrangements trying to get the feature
count from a user selection and I am getting a delay two times for each
query.
My current arrangement is
OGRLayer *queryLayer = dataSource->ExecuteSQL(fullQueryString, NULL,
"generic");
if (queryLayer != NULL)
queryLayer->ResetReading();
OGRFeature *feature = queryLayer->GetNextFeature();
int numFeatures = queryLayer->GetFeatureCount();
. . .Display progress meter then loop reading the features from Oracle
I have tried putting the call to GetFeatureCount first and there is no
apparent difference.
I am reading data from an Oracle database and using GDAL version 1.6.2
on Windows XP
The call to ExecuteSql returns right away but the call to the first
GetNextFeature and the call to GetFeatureCount both have a long delay
depending on the size of the dataset.
I need the feature count to use in a progress popup window to let the
user know what is happening.
Is there a way to only pay for the query time once and still get the
feature count?
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091014/0ad13a8a/attachment.html
