Fwd: [gdal-dev] grass lib not found : gdal-grass plug-in (grass-7.0)
Massimo Di Stefano massimodisasha at yahoo.it
Wed Oct 14 16:05:27 EDT 2009
Hi All.
from a gdal-dev list+irc discussion,
the old patch  no longer work on the up-to date gdal trunk.
the old patch was applied in the trunk plus modification to have the
gdal-grass plug-in
working on grass version < 7 and = 7.
but that sophistication has been broken by a recent change in grass.
probably the reason of the current failure is the addition/removal of
one of the grass lib,
have a "grass-config" script would help certainly to avoid this kind
of failure each time a new lib will be added/removed.
thanks for any interest in this direction.
regards,
Massimo.
Inizio messaggio inoltrato:
> Da: Massimo Di Stefano <massimodisasha at yahoo.it>
> Data: 14 ottobre 2009 21:37:04 GMT+02:00
> A: Markus Neteler <neteler at osgeo.org>
> Cc: gdal-dev at lists.osgeo.org
> Oggetto: Re: [gdal-dev] grass lib not found : gdal-grass plug-in
> (grass-7.0)
> Thanks Markus,
> i tried to apply the patch, but it fails on the actually gdal-trunk
> (revision :  Revision: 17810  )
> i'm tring to see how to apply the patch manually .. but it is 6000
> lines :'(
> this the log tring to apply the patch :
> geofem at geofem:/usr/local/src/gdal$ patch -p0 < /home/geofem/
> Downloads/gdal_grass7_plugin.diff
> patching file frmts/grass/pkg/configure.in
> Hunk #2 succeeded at 152 (offset 9 lines).
> Hunk #62 FAILED at 3395.
> Hunk #65 FAILED at 3446.
> Hunk #67 FAILED at 3534.
> Hunk #68 succeeded at 3630 (offset 78 lines).
> Hunk #69 succeeded at 3694 (offset 78 lines).
> Hunk #70 succeeded at 3712 (offset 78 lines).
> Hunk #71 succeeded at 3793 (offset 78 lines).
> Hunk #72 succeeded at 3854 (offset 78 lines).
> Hunk #73 succeeded at 3978 (offset 78 lines).
> Hunk #74 succeeded at 4008 (offset 78 lines).
> Hunk #75 succeeded at 4023 (offset 78 lines).
> Hunk #76 succeeded at 4136 (offset 78 lines).
> patch: **** malformed patch at line 5577: @@ -3895,7 +4587,9 @@
> Have you any ideas?
> idea .. (but i guess it is totally wrong)
> can i download gdal-grass plug-in from the gdal-revision you applied
> the patch
> and use it on the actual gdal trunk?
> thanks for any suggestion!
> Massimo.
> il giorno 14/ott/09, alle ore 19:09, Markus Neteler ha scritto:
>> On Wed, Oct 14, 2009 at 12:02 PM, Massimo Di Stefano
>> <massimodisasha at yahoo.it> wrote:
>>> Hi All.
>>> I'm tring to build the gdal-grass plug-in (i'm using gdal from svn)
>>> on a debian sid machine,
>>> i had this problem :
>>> geofem at geofem:/usr/local/src/gdal/frmts/grass/gdal-grass-1.7.0$ ./
>>> configure
>>> --with-gdal=/usr/local/bin/gdal-config
>>> --with-grass=/usr/local/grass-7.0.svn/
>>> configure: error: --with-grass=/usr/local/grass-7.0.svn requested,
>>> but
>>> libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to
>>> include
>>> /usr/local/grass-7.0.svn/lib?
>>> i have  :
>>> cat /etc/ld.so.conf.d/grass.conf
>>> have you any clue on how to fix the gdal-grass build ?
>> Yes, see the patch in
>> http://trac.osgeo.org/gdal/ticket/2953
>> Markus
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091014/2ebdf401/attachment.html
