[Gdal-dev] GDALOpenShared error
Fri Oct 23 09:45:12 EDT 2009
alfreale wrote:
> Hi,
> When I import a HDF file with gdal, I've this error:
> A dataset opened by GDALOpenShared should have the same filename.....
> GRASS 6.4.0RC5 (wgs84_lat_long):~ > i.in.spotvgt -a --overwrite --verbose
> file=/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF
> rast=ndvi_test
> Importing SPOT VGT NDVI map...
> Warning 6: A dataset opened by GDALOpenShared should have the same filename
> (/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF)
> and description
> (HDF4_SDS:UNKNOWN:"/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF":0)
Alfreale,
This is a non-critical message just indicated that subsequent GDALOpenShared
calls for this file will not share dataset handles.  I have filed a ticket on
the issue so we can try and improve the HDF4 driver, but the issue should
not affect your activities.  You may disregard the warning.
   http://trac.osgeo.org/gdal/ticket/3200
Best regards,
