[Gdal-dev] GDALOpenShared error
alfreale
alfreale74 at gmail.com
Fri Oct 23 10:03:43 EDT 2009
2009/10/23 Frank Warmerdam [via OSGeo.org]
<ml-node+3878825-86383786 at n2.nabble.com>:
> alfreale wrote:
>> Hi,
>> When I import a HDF file with gdal, I've this error:
>> A dataset opened by GDALOpenShared should have the same filename.....
>> GRASS 6.4.0RC5 (wgs84_lat_long):~ > i.in.spotvgt -a --overwrite --verbose
>> file=/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF
>> rast=ndvi_test
>> Importing SPOT VGT NDVI map...
>> Warning 6: A dataset opened by GDALOpenShared should have the same
>> filename
>> (/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF)
>> and description
>> (HDF4_SDS:UNKNOWN:"/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF":0)
> Alfreale,
> This is a non-critical message just indicated that subsequent GDALOpenShared
> calls for this file will not share dataset handles. I have filed a ticket
> on
> the issue so we can try and improve the HDF4 driver, but the issue should
> not affect your activities. You may disregard the warning.
> http://trac.osgeo.org/gdal/ticket/3200
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, [hidden email]
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> [hidden email]
> ________________________________
> View message @
> http://n2.nabble.com/GDALOpenShared-error-tp3878105p3878825.html
> To unsubscribe from GDALOpenShared error, click here.
Alfredo Alessandrini, Dr.
Post-doc
Department of Environment and Forest (DAF)
Unitus - Viterbo
http://www.unitus.it/dipartimenti/daf/dendro/
View this message in context: http://n2.nabble.com/GDALOpenShared-error-tp3878105p3878921.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091023/4ba4463f/attachment.html
