[gdal-dev] Maintenance report for Sep 25, 2009 to Oct 27, 2009
Chaitanya kumar CH
chaitanya.ch at gmail.com
Wed Oct 28 13:08:10 EDT 2009
Frank,
Please I have updated my maintenance report at
http://trac.osgeo.org/gdal/wiki/MaintenanceReportsByChaitanya
Please find the attached copy of the report.
Best regards,
Chaitanya kumar CH.
#3156: Fixed the problem with xerces library's changes between versions 2 and 3. Also found and fixed a bug that caused segmentation fault in ili driver.
#2270: Tested and applied the patch for HDF5 block size recognition
#3161: Reviewed proposal for gdal_merge.py
#3129: Looked into the norms of contour orientation and gone through the code to get a feel fo the algorithm.
#3166: Researched netcdf and hdf specifications for the size issue.
#3154: Configure snippet is not truly able to manage both netcdf3 and netcdf4
Read up on autoconf
gdal-dev
Chaitanya kumar CH
chaitanyach at gmail.com
