[gdal-dev] GDAL DataType class
Pinner, Luke
Luke.Pinner at environment.gov.au
Wed Oct 28 19:20:44 EDT 2009
You could easily roll your own.
from osgeo import gdal
class GdalDataType(object):
def __init__(self, nbits, Float, Complex):
for i in range(0,gdal.GDT_TypeCount):
self.DataType=None
DataType=i
DataTypeName=gdal.GetDataTypeName(i)
DataTypeSize=gdal.GetDataTypeSize(i)
DataTypeIsFloat ='Float' in DataTypeName
DataTypeIsComplex=gdal.DataTypeIsComplex(i)==1
if DataTypeSize==nbits and DataTypeIsFloat==Float and
DataTypeIsComplex==Complex:
self.DataType=DataType
self.DataTypeName=DataTypeName
self.DataTypeSize=DataTypeSize
self.DataTypeIsFloat=DataTypeIsFloat
self.DataTypeIsComplex=DataTypeIsComplex
break
if self.DataType is None: raise TypeError, 'No matching DataType
found'
gdt=GdalDataType(nbits=32, Float=True, Complex=False)
print gdt.DataTypeName
Luke
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Luca Fasano
Sent: Thursday, 29 October 2009 3:19 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] GDAL DataType class
Hi all,
I need a way to retrieve a GDAL DataType (its code or its string name,
it's the same) starting from all information on it. Does it exist a
class or method to to this?
For example:
GdalDataType(nbits=32, float=True, Complex=True) -> gdal.GDT_CFloat32
I use Python bindings for GDAL.
I'd like to avoid building the string manually (i.e.
'GDT_'+'C'+'Float'+'32')
Thanks
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
