[gdal-dev] GDAL DataType class
Pinner, Luke Luke.Pinner at environment.gov.au
Wed Oct 28 19:56:32 EDT 2009
Ooops... I neglected the signed check.
from osgeo import gdal
class GdalDataType(object):
    def __init__(self, nbits, Float, Signed=True, Complex=False):
        for i in range(0,gdal.GDT_TypeCount):
            self.DataType=None
            DataType=i
            DataTypeName=gdal.GetDataTypeName(i)
            DataTypeSize=gdal.GetDataTypeSize(i)
            DataTypeIsFloat ='Float' in DataTypeName
            DataTypeIsSigned = DataTypeIsFloat or DataTypeName[0:4] in
['Byte','UInt']
            DataTypeIsComplex=gdal.DataTypeIsComplex(i)==1
            if DataTypeSize==nbits and DataTypeIsFloat==Float and
DataTypeIsSigned==Signed and DataTypeIsComplex==Complex:
                self.DataType=DataType
                self.DataTypeName=DataTypeName
                self.DataTypeSize=DataTypeSize
                self.DataTypeIsFloat=DataTypeIsFloat
                self.DataTypeIsSigned=DataTypeIsSigned
                self.DataTypeIsComplex=DataTypeIsComplex
                if DataTypeIsSigned:
                    self.DataTypeRange=[-2**(nbits-1),2**(nbits-1)]
                else:
                    self.DataTypeRange=[0,2**nbits-1]
                break
        if self.DataType is None: raise TypeError, 'No matching DataType
found'
gdt=GdalDataType(nbits=32, Float=True, Complex=False)
print gdt.DataTypeName
-----Original Message-----
Sent: Thursday, 29 October 2009 10:21 AM
To: 'Luca Fasano'; gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] GDAL DataType class
You could easily roll your own.
    def __init__(self, nbits, Float, Complex=False, Signed=False):
            self.DataType=None
            DataType=i
                break
found'
Luke
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Luca Fasano
Sent: Thursday, 29 October 2009 3:19 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] GDAL DataType class
Hi all,
I need a way to retrieve a GDAL DataType (its code or its string name,
it's the same) starting from all information on it. Does it exist a
class or method to to this?
For example:
GdalDataType(nbits=32, float=True, Complex=True) -> gdal.GDT_CFloat32
I use Python bindings for GDAL.
I'd like to avoid building the string manually (i.e.
'GDT_'+'C'+'Float'+'32')
Thanks
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
