[gdal-dev] gdal_translate problems...
Riki Tiki
mongoose_riki at mail.ru
Wed Sep 2 11:29:55 EDT 2009
hi,
i am using the following command to convert from raster to geotiff
gdal_translate -of GTiff test test.tif
it outputs the following:
ERROR 1: Unknown base item type : 4
Input file size is 221, 232
0...10...20...30...40...50...60...70...80...90...100 - done.
Please can you tell me what are those errors mean? And possible solution to avoid it,...?
thanks,
Riki
