[gdal-dev] GDAL: How to create one NITF image from CIB CD
Rydzak, Carol-P28503
Carol.Rydzak at gdc4s.com
Thu Sep 3 15:35:41 EDT 2009
I am trying to use GDAL utilities (on a Solaris 10 system) against CIB
files (from a CD) to convert them to a single NITF image.
When I run gdal_translate, it doesn't seem to accept the a.toc, but it
does create a one-to-one nitf image for each CIB file the command is run
against.
Is there a GDAL command that takes the table of contents file and
processes all the CIB frames into one NITF image? Or takes all the .ntf
files that get created and stitches them together into one .ntf image?
Thank you,
Carol Rydzak
General Dynamics C4 Systems
Phone: (480) 441-7405
Email: Carol.Rydzak at gdc4s.com
This email message is for the sole use of the intended recipient(s) and
may contain GDC4S confidential or privileged information. Any
unauthorized review, use, disclosure or distribution is prohibited. If
you are not an intended recipient, please contact the sender by reply
email and destroy all copies of the original message.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090903/7e42b47b/attachment.html
