[gdal-dev] convert shape file to ascii raster
Jonas Malmqvist
jonas.malmqvist at fsdynamics.se
Mon Sep 7 05:03:36 EDT 2009
Hi I tried out some different ways an at the end I chose this way, not
python but you use the same commands I guess.
-Concatenate four shapefiles:
ogr2ogr filemerged.shp mdv07xx1.shp
ogr2ogr -update -append filemerged.shp mdv07xx1.shp -nln filemerged
ogr2ogr -update -append filemerged.shp mdv07xx2.shp -nln filemerged
ogr2ogr -update -append filemerged.shp mdv07xx3.shp -nln filemerged
ogr2ogr -update -append filemerged.shp mdv07xx4.shp -nln filemerged
-Create an ARC/INFO textfile with one pixel representing the
window/region of intrest:
the text file window.asc contains the following:
ncols 1
nrows 1
xllcorner 1283000
yllcorner 6403000
cellsize 30000
NODATA_value -9999
0
-Increase the resolution on the ARC/Info window and convert i to Geotif:
gdal_translate window.asc -of GTiff -outsize 300 300 window_high_res.tif
-Rasterize the shapefile onto the Geotif:
gdal_rasterize -a shapefile_field_name -l _shape_file_layer
filemerged.shp window_high_resolution.tif
-And last convert the high res Geotif to an ARC/Info ascii file:
gdal_translate -of AAIGrid height_high_res.tif height_high_res.asc
Good luck!
-Jonas
Jonas Malmqvist
FS Dynamics AB
Jungmansgatan 31
SE-413 11 Göteborg
Sweden
Phone: +46 (0)31 720 71 45
Fax: +46 (0)31 761 99 49
E-mail: jonas.malmqvist at fsdynamics.se
Oz Nahum wrote:
> Hi,
> I've been using gdal-rasterize for quite a while now in my python
> scripts. It only posses on difficulty to me, since it forces me to use
> the tiff format I need to create a template before creating the raster.
> Does any one know of a quick way of doing the template? Alternatively,
> can I use other pathway to create ascii raster from shape files with
> out the creation of templates ?
> Can someone direct me to a python solution ?
> Many thanks,
> Oz Nahum
> Graduate Student
> Center for Applied Geosciences
> University of Tuebingen
> Imagine there's no countries
> It isn't hard to do
> Nothing to kill or die for
> And no religion too
> Imagine all the people
> Living life in peace
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090907/2e50ff86/attachment.html
