[gdal-dev] Latest ShapeLib
Chaitanya kumar CH
chaitanya.ch at gmail.com
Wed Sep 9 10:16:29 EDT 2009
Bhaskar,
Any work done on the shapelib in GDAL's shapefile driver that is not entered
into the main stream shapelib 'may' cause problems with other applications.
If you intend to have the latest code, you can look at OGR's shapefile
driver code.
You can find OGR's shapefile driver's makefiles for gcc and VC++ at
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/shape
On Wed, Sep 9, 2009 at 7:16 PM, spbhasker bachi <spbhasker at gmail.com> wrote:
> Anyone having the Latest ShapeLib ???
> The Latest one v 1.2.10 is located @ http://dl.maptools.org/dl/shapelib/
> But in the GDAL trunks i have seen Frank do a Lot of Version for the
> ShapeFil.H & subsequents Codes.. of DBF
> ANyone having the Latest ShapeLib with the Latest Makefile pl send it
> across..
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090909/47748f66/attachment-0001.html
