[gdal-dev] Latest ShapeLib
spbhasker bachi spbhasker at gmail.com
Wed Sep 9 10:31:45 EDT 2009
Thank you Chaitanya.
I had some vintage code.. wanted to use the Latest Shapelib to upgrade
that..
Cheers
Bhasker
On Wed, Sep 9, 2009 at 7:46 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Bhaskar,
> Any work done on the shapelib in GDAL's shapefile driver that is not
> entered into the main stream shapelib 'may' cause problems with other
> applications. If you intend to have the latest code, you can look at OGR's
> shapefile driver code.
> You can find OGR's shapefile driver's makefiles for gcc and VC++ at
> http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/shape
> On Wed, Sep 9, 2009 at 7:16 PM, spbhasker bachi <spbhasker at gmail.com>wrote:
>> Anyone having the Latest ShapeLib ???
>> The Latest one v 1.2.10 is located @  http://dl.maptools.org/dl/shapelib/
>> But in the GDAL trunks i have seen Frank do a Lot of Version for the
>> ShapeFil.H & subsequents Codes.. of DBF
>> ANyone having the Latest ShapeLib with the Latest Makefile pl send it
>> across..
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090909/bf531f94/attachment.html
