[gdal-dev] gdalwarp fills nulls?
Greg Coats
gregcoats at mac.com
Fri Sep 11 12:05:36 EDT 2009
The GDAL default value for GDAL_CACHEMAX is 40 MB. I routinely set up
my gdal_translate scripts to run with a larger value for GDAL_CACHEMAX.
export GDAL_CACHEMAX_value=50
gdal_translate --config GDAL_CACHEMAX ${GDAL_CACHEMAX_value}
In my benchmark tests, I have observed that this small increase in
GDAL_CACHEMAX has dramatically reduced processing time by a factor of
more than 60, from 10473 to 166 seconds.
I do not see any information about a -wm option on these web pages
http://www.gdal.org/gdal_utilities.html
http://www.gdal.org/gdal_translate.html
I would appreciate information about the -wm option. What is the
default value? Are the units MB of memory?
Greg
On Sep 11, 2009, at 11:42 AM, William Kyngesburye wrote:
> Hmm, yes that one works for me. I simplified my example for the
> email, maybe there's a memory problem, or raster size problem?
> I originally tried to resample a GRASS raster DEM directly. It's
> really 1000m cell size, 12809x18192 float cells, and want to
> resample to 21000m and 7000m. That wasn't working so I exported to
> Geotiff (Int16 cells) with r.out.gdal. The exported image has the
> nulls as -32768. That doesn't work either.
> ... ah! memory! I just tried with -wm 250 and I get the nulls. And
> the nasty artifacts. I think I want the nulls filled now ;) I saw
> a bug about this on the tracker but it was fixed. Maybe this is a
> different problem?
> On Sep 10, 2009, at 5:56 PM, Even Rouault wrote:
>> Selon William Kyngesburye <woklist at kyngchaos.com>:
>> I don't manage to reproduce your issue neither with trunk nor with
>> 1.6.2 with a
>> indem.tif generated by the following python script :
>> import gdal
>> import osr
>> ds = gdal.GetDriverByName('GTiff').Create('indem.tif', 500, 500, 1,
>> gdal.GDT_Int16)
>> ds.SetGeoTransform([500000, 10, 0, 45000000, 0, -10])
>> sr = osr.SpatialReference()
>> sr.ImportFromEPSG(32631)
>> ds.SetProjection(sr.ExportToWkt())
>> ds.GetRasterBand(1).Fill(-32768)
>> ds.GetRasterBand(1).SetNoDataValue(-32768)
>> ones = ''
>> for i in range(50*50):
>> ones = ones + '\001\000'
>> ds.GetRasterBand(1).WriteRaster(225,225,50,50, ones, 25, 25)
>> ds = None
>> and
>> gdalwarp -tr 100 100 -ot Int16 -r lanczos -dstnodata -32768
>> indem.tif outdem.tif
>> You need to specify -dstnodata -32768. The result I get is as
>> expected a square
>> of ones at the middle of nodata values at -32768 (except that due
>> to a strange
>> behaviour of lanczos you get some artifacts at the edge of the
>> square).
>>> Maybe I'm missing something? I'm trying to resample a DEM, with
>>> null/
>>> nodata values in oceans, using gdalwarp. No matter what options
>>> I've
>>> used so far, all the resampled nodata areas get filled with 0.
>>> GDAL 1.6.2
>>> So far I've tried (src res 10, nodata -32768 defined in src):
>>> gdalwarp -tr 100 100 -ot Int16 -r lanczos indem.tif outdem.tif
>>> indem.tif
>>> outdem.tif
>>> gdalwarp -tr 100 100 -ot Int16 -r lanczos -dstalpha indem.tif
>>> outdem.tif
>>> The last time I used gdalwarp, with nulls, was back at 1.5.x, and it
>>> worked then, though I was projecting data (-t_srs), instead of only
>>> resampling. (I'd have to dig up an old 1.5 to see if it still
>>> works)
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "I ache, therefore I am. Or in my case - I am, therefore I ache."
>>> - Marvin
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> "History is an illusion caused by the passage of time, and time is
> an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
