[gdal-dev] gdalwarp fills nulls?
William Kyngesburye woklist at kyngchaos.com
Fri Sep 11 11:42:44 EDT 2009
Hmm, yes that one works for me.  I simplified my example for the
email, maybe there's a memory problem, or raster size problem?
I originally tried to resample a GRASS raster DEM directly.  It's
really 1000m cell size, 12809x18192 float cells, and want to resample
to 21000m and 7000m.  That wasn't working so I exported to Geotiff
(Int16 cells) with r.out.gdal.  The exported image has the nulls as
-32768.  That doesn't work either.
... ah! memory!  I just tried with -wm 250 and I get the nulls.  And
the nasty artifacts.  I think I want the nulls filled now ;)  I saw a
bug about this on the tracker but it was fixed.  Maybe this is a
different problem?
On Sep 10, 2009, at 5:56 PM, Even Rouault wrote:
> Selon William Kyngesburye <woklist at kyngchaos.com>:
> I don't manage to reproduce your issue neither with trunk nor with
> 1.6.2 with a
> indem.tif generated by the following python script :
> import gdal
> import osr
> ds = gdal.GetDriverByName('GTiff').Create('indem.tif', 500, 500, 1,
> gdal.GDT_Int16)
> ds.SetGeoTransform([500000, 10, 0, 45000000, 0, -10])
> sr = osr.SpatialReference()
> sr.ImportFromEPSG(32631)
> ds.SetProjection(sr.ExportToWkt())
> ds.GetRasterBand(1).Fill(-32768)
> ds.GetRasterBand(1).SetNoDataValue(-32768)
> ones = ''
> for i in range(50*50):
>    ones = ones + '\001\000'
> ds.GetRasterBand(1).WriteRaster(225,225,50,50, ones, 25, 25)
> ds = None
> and
> gdalwarp -tr 100 100 -ot Int16 -r lanczos -dstnodata -32768
> indem.tif outdem.tif
> You need to specify -dstnodata -32768. The result I get is as
> expected a square
> of ones at the middle of nodata values at -32768 (except that due to
> a strange
> behaviour of lanczos you get some artifacts at the edge of the
> square).
>> Maybe I'm missing something?  I'm trying to resample a DEM, with
>> null/
>> nodata values in oceans, using gdalwarp.  No matter what options I've
>> used so far, all the resampled nodata areas get filled with 0.
>> GDAL 1.6.2
>> So far I've tried (src res 10, nodata -32768 defined in src):
>> gdalwarp -tr 100 100 -ot Int16 -r lanczos indem.tif outdem.tif
>> gdalwarp -tr 100 100 -ot Int16 -r lanczos -dstnodata -32768 indem.tif
>> outdem.tif
>> gdalwarp -tr 100 100 -ot Int16 -r lanczos -dstalpha indem.tif
>> outdem.tif
>> The last time I used gdalwarp, with nulls, was back at 1.5.x, and it
>> worked then, though I was projecting data (-t_srs), instead of only
>> resampling.  (I'd have to dig up an old 1.5 to see if it still works)
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
>> - Marvin
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
