[gdal-dev] gdalwarp fills nulls?
Even Rouault
even.rouault at mines-paris.org
Thu Sep 10 18:56:08 EDT 2009
Selon William Kyngesburye <woklist at kyngchaos.com>:
I don't manage to reproduce your issue neither with trunk nor with 1.6.2 with a
indem.tif generated by the following python script :
import gdal
import osr
ds = gdal.GetDriverByName('GTiff').Create('indem.tif', 500, 500, 1,
gdal.GDT_Int16)
ds.SetGeoTransform([500000, 10, 0, 45000000, 0, -10])
sr = osr.SpatialReference()
sr.ImportFromEPSG(32631)
ds.SetProjection(sr.ExportToWkt())
ds.GetRasterBand(1).Fill(-32768)
ds.GetRasterBand(1).SetNoDataValue(-32768)
ones = ''
for i in range(50*50):
ones = ones + '\001\000'
ds.GetRasterBand(1).WriteRaster(225,225,50,50, ones, 25, 25)
ds = None
and
gdalwarp -tr 100 100 -ot Int16 -r lanczos -dstnodata -32768 indem.tif outdem.tif
You need to specify -dstnodata -32768. The result I get is as expected a square
of ones at the middle of nodata values at -32768 (except that due to a strange
behaviour of lanczos you get some artifacts at the edge of the square).
> Maybe I'm missing something? I'm trying to resample a DEM, with null/
> nodata values in oceans, using gdalwarp. No matter what options I've
> used so far, all the resampled nodata areas get filled with 0.
> GDAL 1.6.2
> So far I've tried (src res 10, nodata -32768 defined in src):
> gdalwarp -tr 100 100 -ot Int16 -r lanczos indem.tif outdem.tif
> outdem.tif
> gdalwarp -tr 100 100 -ot Int16 -r lanczos -dstalpha indem.tif outdem.tif
> The last time I used gdalwarp, with nulls, was back at 1.5.x, and it
> worked then, though I was projecting data (-t_srs), instead of only
> resampling. (I'd have to dig up an old 1.5 to see if it still works)
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
