[gdal-dev] (no subject)
Riki Tiki mongoose_riki at mail.ru
Thu Sep 17 13:48:40 EDT 2009
@Frank and Hermann: Thanks a lot!
My other question is as follows:
1) gdal_translate -of AAIGrid a.tif a.asc
it creates the following: a.asc (ASC File), a.asc.aux (XML Document), and a (IDL project file)...
now to do the reverse i do the following:
2) gdal_translate -of GTiff a.asc a.tif
it creates: a.tif (TIF Image)
but when i open a.tif with ArcGIS it shows that its statistics are not calculated...
Can you tell me how to create the 2) with statistics already computed? So that when i open it in ArcGis for example I do not have to ask ArcGIS to compute the statistics? Thanks a lot!
@Joaquim:
when the AAIGrid is created its format is of the following form:
ncols        250
nrows        398
xllcorner    X.Y
yllcorner    Z.W
cellsize     30.863820105342
NODATA_value    255
 255 255 255 255 255 255 255 255.....
Now, I will be changing the for example this to the following
ncols        250
nrows        398
xllcorner    X.Y
yllcorner    Z.W
NODATA_value    255
 255 255 2 255 1 255 0 255.....
(this is only to show my intention...)
Best wishes all of you,
Riki
