[gdal-dev] Re: GDAL 1.7.0 download?
Even Rouault
even.rouault at mines-paris.org
Tue Sep 29 13:04:08 EDT 2009
Selon Hermann Peifer <peifer at gmx.eu>:
Well, the documentation is correct. gdaldem will be officially included in
to-be-released GDAL 1.7.0.
http://trac.osgeo.org/gdal/browser/branches/1.6/gdal/apps doesn't show any sign
of it...
I guess you have backported it yourself or someone did it for you. The source
code should indeed compile fine against any GDAL version.
> Chris Emberson wrote:
> > Hi,
> > Am trying to use gdaldem but it says this is only available with GDAL
> 1.7.0,
> > "Tools to analyze and visualize DEMs. (since GDAL 1.7.0)"
> As far as I can see, the documentation is not correct in this case.
> $ gdaldem --version|head -1
> GDAL 1.6.2, released 2009/07/31
> Hermann
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
