[gdal-dev] Re: GDAL 1.7.0 download?
Hermann Peifer
peifer at gmx.eu
Tue Sep 29 14:09:23 EDT 2009
You are right. Now I remember that some time ago, I made an extra effort
to get hold of this useful utility...
Hermann
Even Rouault wrote:
> Selon Hermann Peifer <peifer at gmx.eu>:
> Well, the documentation is correct. gdaldem will be officially included in
> to-be-released GDAL 1.7.0.
> http://trac.osgeo.org/gdal/browser/branches/1.6/gdal/apps doesn't show any sign
> of it...
> I guess you have backported it yourself or someone did it for you. The source
> code should indeed compile fine against any GDAL version.
>> Chris Emberson wrote:
>>> Hi,
>>> Am trying to use gdaldem but it says this is only available with GDAL
>> 1.7.0,
>>> "Tools to analyze and visualize DEMs. (since GDAL 1.7.0)"
>> As far as I can see, the documentation is not correct in this case.
>> $ gdaldem --version|head -1
>> GDAL 1.6.2, released 2009/07/31
>> Hermann
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
