[gdal-dev] getcolortable is null
Wed Apr 7 11:02:11 EDT 2010
weixj2003ld wrote:
> Thk u very much.
> I have two questions.
> 1.If I want to use the following combination,
> Red=Band3
> Green=Band2*0.8+band4*0.2;
> Blue=band1
Wei,
This will require programming or scripting.   It cannot be done
with the stock commandline tools.
> 2. what is the general combination for good look jpeg file?
That depends greatly on the source sensor and the goals of the visualization.
A 4,2,1 b  false color band combination is common with Landsat imagery,
butit can be disputed whether it looks good or not.  Also, constrast
stretching is often also desirable on satellite imagery for best
visualization.
Best regards,
