[gdal-dev] Re: Bulding VRT files from HDF sds
Jose Gomez-Dans jgomezdans at gmail.com
Fri Apr 16 14:16:56 EDT 2010
More on this
On 16 April 2010 19:04, Jose Gomez-Dans <jgomezdans at gmail.com> wrote:
> I want to put together a time series of MODIS datasets in VRT, the
> originals being in HDF EOS format.
It appears that if I convert my HDF sds into standard GeoTIFFs
(gdal_translate -of GTiff .....), and then generate by  VRT, it all works as
it should!
It will probably solved my problem in practice, but I don't see why the HDF
sds shouldn't work?
Thanks,
Jose
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100416/06c1e685/attachment.html
